Just installed my ATI TV Wonder and it works great. Only problem is it seems to have un installed my sound blaster live.
Anyone else ever have this issue.
Should I jsut try to reinstall sound drivers or would that over write the tv tuner drivers?
vcdman24,
YES. Reinstall your snd drivers!
Also, you may want to (to keep handy) RT-click the spkr
on the tray and select "Adjust Audio Properties" and then
click on the "Recorder's" Icon and note the [x] Line-in
is checked. Depending on each system/sound card, you
may have to wrestle with this each time you have to start
your ATI-TV Wonder and/or record from DIFFerent apps, ie
VD or avi_io for starters. If this happens to you, you'll
get the hang of it, till someone comes up with a solution.
I hope you start to enjoy your ATW card!!
Sample Clips . . .revised web site
Live Video Mixing with Flash Media Live Encoder
By fuggles7 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2012, 14:08 -
How to broadcast a live satellite TV by Adobe Flash Media Live Encoder
By mrweb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Aug 2010, 21:08 -
removed
By draven1968 in forum User guidesReplies: 0Last Post: 4th Aug 2008, 06:10 -
can this be removed
By tryintoo in forum AudioReplies: 4Last Post: 23rd Sep 2007, 12:23
