ok so i had 2 cds of mpeg and joined them and tryed to burn it on nero but it said i'm over 5gb and the file is like 1.7gb. i don't know what to do i tryed alot of programs still stuck. if there is a program that can compress the size or something. i really don't know what to do. so please reply thanx
How exactly have you done the "joining"?
There can't be anything to compress, as 2 CDs always fit on one DVD?!
Tip: Demultiplex the 2 MPEG CDs, and use a real authoring program (ifoedit, TDA, dvdlab, dvdauthor...) to create a DVD structure. Then burn it...GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Which mpeg joining s/w did you use? It is possible that you joined mpeg file is corrupt therefore Nero is showing incorret size and will not burn it.
If you want to put the files on DVD there is no need to join them. Use a DVD authoring s/w like TMPGENc DVD Author, DVDLab and author your DVD. The 2 mpeg files will be put on the DVD with the corrent DVD structure and play sequentially. If that is what you want.
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 14:22 -
burning and authored mpeg to dvd?
By just in forum Newbie / General discussionsReplies: 21Last Post: 12th Dec 2008, 09:06 -
Audio messed up when burning .mpeg on DVD +R
By greenda4 in forum AudioReplies: 16Last Post: 19th Nov 2008, 15:52 -
AVI to MPEG conversion and DVD burning
By mc-help in forum Video ConversionReplies: 2Last Post: 5th Jan 2008, 16:08
