Hi everybody!
I´ve been searching like mad how to convert these mpeg files (640x480) so that I can burn them as dvd´s. Framerate is 16 fps. Does anybody have a clue? As you probably guessed I´m new at this, so any help is welcome. I´ve tried Tmpeg, but I couldn´t fix it with the program (way complicated...)
You need to make sure the MPEGs are DVD-compliant. You can do this by editing, then saving as compliant (see "What Is - DVD" upper left corner). You can also do it by opening it in an authoring app and then generating the DVD files. The app will convert the video to compatible and generate the files you need to burn a DVD Video, or it'll do the burning as part of the process if you want.
Converting file to play on sony cybershot dsc tx1 help needed please
By arcalis in forum DVD RippingReplies: 0Last Post: 20th Dec 2010, 12:53 -
doing a video recording with a Sony CyberShot DSC-W220 camera
By p_s_92 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jul 2010, 14:29 -
How to convert dvd movies to DX50
By mbworldz in forum Video ConversionReplies: 8Last Post: 18th Jan 2010, 13:26 -
Sony Cybershot Camera Video MPG
By waynepixel in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2009, 12:30 -
Convert movies to DVD
By neonblade in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2007, 02:32
