From what I understand, people are having difficulty connecting non-HDCP sources to HDMI connectors (HDMI is DVI-HD plus 10 and 12bit modes, plus audio and control). I guess mileage will vary with the transition DVI equipped sets which are now mostly discontinued as HDMI takes over.
The Bravo D1 was non-HDCP and is discontinued. Used ones will probably sell at a premium. The new Bravo D2 has HDCP. This article is pretty good at framing the HDCP source issues. Bottom line, all of us that bought non HDCP equiped HDTV sets will be left high and dry eventually.
http://www.hometheaterhifi.com/volume_11_4/feature-dvi-hdmi-hdcp-connections-11-2004.html
Connecting non-HDCP sources to DVI and HDMI TV set connectors seems to be a case by case issue. Some work most don't from what I'm reading. It seems to be related to how the TV set manufacturer programmed the HDMI port defaults.
There is a fair amount of controversy as to whether HDCP will be allowed from a Home Theater PC (HTPC) and how it will be controlled. Hollywood wants tight control of HDCP sources and anything coming out of the PC puts them into war mode. I'm about 3 months behind on this controversy and will try to catch up. Current HTPCs and ATI's AIW etc. use the analog component or S-Video outputs, not DVI (digital pins) or HDMI.
Results 31 to 32 of 32
Someone will probably figure out a way to hack HDCP compliant players to work with non-HDCP displays.
Capturing Xbox 360 Video Using Component HD AV Cable
By FrankieB in forum Capturing and VCRReplies: 2Last Post: 18th Feb 2009, 12:21 -
Help! Mac Mini (dvi or vga) out to Component Cable in on Projector
By soundsinamotion in forum DVB / IPTVReplies: 3Last Post: 7th Dec 2008, 22:40 -
DVI/Component cable
By ajcstr in forum DVB / IPTVReplies: 9Last Post: 16th Oct 2008, 05:25 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 06:49 -
ATI DVI-to-Component Video Dongle and HD2400
By Robert Simandl in forum Media Center PC / MediaCentersReplies: 1Last Post: 7th Nov 2007, 11:25
