Ok. Time to spend some money on some new media.
I have used bulkpak and they were not that great. I found that when I used DVDShrink, the film broke up at the end.
Can anyone recommend some good brands. I dont want to spend a fortune, but i dont want to buy any cheap rubbish
Thanks.
Datawrite yellow tops 8x (i burn them at 12x) dvd+r PRODISC R03 for £25 per 100
Cheap, they work in everything i have tried (PS2,Xbox,mine and family/friends dvd players etc) with zero problems. -
Are you asking for brands? If so, try Fujifilm, or Maxell's made in Japan.
TDK can be good. (but theres a risk with TDK as they can be several types..)
If you're buying online, just look for Taiyo Yuden media, from a reputable dealer.
Seth:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
The above suggestions are good ones. Good media is so cheap nowadays I don't understand why people still buy the cheap stuff like bulkpaq and Princo.
Taiyo Yuden is what I recommend
I cannot find any on Ebay that are Taiyo branded, but they are using their dye. Should I use them or not?
Recommendations Please, Blu-ray Player with USB HDD support
By Hollywood_12 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Mar 2012, 16:53 -
Media recommendations...
By biged670 in forum MediaReplies: 16Last Post: 9th Feb 2009, 19:38 -
HD tuner recommendations?
By geeeeoffff in forum DVB / IPTVReplies: 8Last Post: 13th Jan 2009, 10:44 -
Recommendations for a Hi-8 deck?
By Big Chupa in forum Capturing and VCRReplies: 2Last Post: 11th Oct 2008, 16:20 -
I am looking for recommendations
By Tidy in forum DVD & Blu-ray WritersReplies: 5Last Post: 8th Jan 2008, 12:48
