i was sittin on my puter just kinda doin the normal thing. a yahoo im popped up that said "are u there, blah blah blah...check out my profile" so i go to click on an option to view profile but as soon as i did my computer restartsi thought it was kinda weird...when everything gets back up and running msn messenger is missing. the only thing showing is blank white boxes where msn messenger shortcuts used to be. and when i click on it gives me "incorrect parameter" which means it was basically uninstalled right? i dont really want to rule out anything but what the hell could have caused that besides getting hacked?
Results 1 to 11 of 11
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
NOOOOOOOOOOOO! Actually it DOES sound like some kind of messenger virus, if you're lucky (?) it's just spyware. Update everything and run all the normal scans.
Nothing can stop me now, 'cause I don't care anymore. -
hehe, it's kinda my fault. i was too lazy to upgrade to sp2, had the firewall and av updates flashin infront of my face for a couple days. thats the first thing i did after it happened was update everything
i think messenger was pretty open for attack. ah well.
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Hello,Originally Posted by glockjs
Shame on you! That should be a lesson to not let your gaurd down
the last time i had a virus on my computer, i ended up formatting my hard drive and starting again clean. soon as WinXP was installed, i installed SP2, norton systemworks, adaware SE, and the enhanced firewall on my nforce4 motherboard as well as my firewall router.
Guess ive minised the chances of another virus attack, better to be safe than sorry. -
i get sick of updates
maybe it's time to explore this crazy little world people call linux
crap, i am unable to access some websites (using either internet explorer or firefox) due to my nforce4 network access manager and firewall. ive tried to change the settings but no luck. the only way it works is to completely uninstall network access manager. thats one protection wasted.
there should be away to lower the security levels and set allowances...no?
ive even turned the nforce firewall off but still no luck. im sure there is a way but i cant figure it out, so i had to unistall it. anyway, i still do have a firewall router and SP2 firewall, should be enough. Its a pity that i cant use my motherboard firewall and security settings.
I also had problems accessing the net using firefox, msn messenger wouldn't work, but i changed the settings so they would work, and they did.
but some websites wont work, i have problems using ebay, and even posting topics in this forum. the website just hangs and does nothing. -
Originally Posted by waheed
nforce4 is pretty new..i'd keep an eye out for an update or two that might solve the prob. im sure your not the only one with probs
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Weird Mouse?
By fairytale00 in forum ComputerReplies: 1Last Post: 7th Jun 2010, 02:07 -
Weird Folder
By mn072065 in forum ComputerReplies: 7Last Post: 28th May 2008, 10:34 -
Weird Audio
By Thr0ttleman in forum Video Streaming DownloadingReplies: 8Last Post: 4th Apr 2008, 05:57 -
colours are weird?
By bennyboyt in forum Newbie / General discussionsReplies: 5Last Post: 23rd Dec 2007, 19:47
