Need to know what "codecs" are needed to capture and convert vhs to dvd with this tool have managed to capture but when trying to encode withTMPEGEnc keep getting error codes saying "not supported", anyone any ideas,I am using the capture software that came with it "EZDVse",or is there an other capture software that is better than the Canopus one, who don't seem to have any support for this software now.I used this software and had no problems with Win 98se but have upgraded to Win xp home edition and have had nothing but problems,seems I have lost some of my "codecs" along the way, any advice would be welcome.
Results 1 to 13 of 13
The ADVC-100 has its own hardware codec that converts NTSC or PAL to DV format in real time. It produces a DV stream that must be buffered and converted into a file at the PC end.Originally Posted by mick094
You can do this with Windows Movie Maker 2* or a simple DV I/O utility like WinDV or DVIO. The result is a standard DV-AVI file that can be read by many utilities such as TMPGEnc DVD Author.
*Movie Maker2 instructions.
1. Capture from Video Device
2. Select DV Device
3. Name the capture file (note directory)
4. Video Setting = "Digital Device Format (DV-AVI)"
5. Capture manually, capture the portion of the tape of interest.
Done.
Note: Expect 13.5GB per hour of DV material. -
advc should have shipped with the canopus DV codec. If not you can probably download it from canopus.
Read my blog here.
download the panasonic codec. i use the capture program SCENALYZER LIVE. then use TMPGE to encode, TMPGE DVD AUTHOR to author and NERO to burn.
Thanks for the info ,regarding the canopus codec ,I looked at that but it says "not to install if ezdv is already installed".
Have managed to capture the video but when I come to encode it I get a "green screen" , -
Hmmm those solid colored screens are usually associated with Macrovision copyright protection. Is the tape really old, used a lot, 3 rd 4th generation? I don't know what the Canopus does when it detects MV so I'm just guessing here.... I probably should experment.
Edit: You said you can capture it? Can you play it? -
My ADVC-50 did not come with any programs to install or any Codecs (as edDV says) the Canopus Codec is in the ADVC unit. The only program that it won't capture with is Virtualdub, but installation of the Panasonic Codec lets me open any captured file to edit. The Panasonic Codec isn't needed if you don't want to use Virtualdub.
As a suggestion, try uninstalling ESDV and don't try to install the Canopus Codec - just see if you can capture and encode using the programs suggested by edDV (also DVAPP is another useful one) and then see if the resulting capture can be encoded.
Using the likes of DVAPP, Windows Movie Maker (1/2), Edit Studio and TMPGEnc, I have not had to load a single Codec or special software to make the Canopus work.
Hope that this is helpful.
@ The Coalman - The Canopus ADVC-100 has an automatic Macrovision defeat funtion, so this shouldn't be an issue. However, the Maorovison on the ADVC-50 shows as a 'brown haze' over the film at regular intervals.
Edits: tying error!Cole -
You could try codec sniper, it might identify codec problems for you. Be careful using it..... might want to get some advice if you find anything.
Originally Posted by Cole
I've heard that line before.... www.nepadigital.com/mv BTW the tape I discuss on that page captured perfectly with the Canopus
Do you have areally old Canopus, the recent ones you need to use the input button "hack" to turn it off. I've also seen reports that hte newer ones such as mine it doesn't work.
I have a two year old (ish) ADVC-50 and have to use the old "sixth jumper switch removal hack" for Macrovision defeat.Originally Posted by thecoalman
Cole -
I am just going to have another go with another one this is one of a friends that he had sent to him from america transfered from ntsc to pal and see if that works cannot accept that I have "macrovision" on my tape that I filmed with my own camcorder will also try the "panasonic" codec while I am at it
It's not that it's on the tape but some capture devices falsely detect it as it is, I doubt that is your issue but when I hear solid colored screens that's a MV flag for me because that is one of the things a capture device will produce when MV is detected.Originally Posted by mick094
I'm guessing it's a codec issue... Good Luck!
canopus advc100 problems--any suggestions?
By esek64 in forum Video ConversionReplies: 3Last Post: 14th Aug 2010, 04:26 -
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
Canopos ADVC100 doesn't work with Vista 64?
By something random in forum Capturing and VCRReplies: 4Last Post: 23rd Oct 2009, 19:33 -
Fuzzy Video using ADVC100
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 16th Jun 2009, 02:17 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49
