I just bought a PAL VCR for the purpose of capturing PAL VHS tapes in PAL format.
I playback the tape on a JVC HR-J82MS multisystem VCR into the Canopus ADVC-100 and the preview and capture are black and white instead of color. Everything is set to PAL (VCR, capture software, ADVC-100), I have tried all the "color system" settings on the VCR and all the toggle switches on the ADVC. My capture app is Sony Vegas Video but I also tried Scenalyzer to be sure, and it was also black and white.
The back of the VCR has a built-in RF converter (G, K) but I can't connect the RF out to the ADVC-100.
Am I making some obvious mistake?
Do I need another piece of hardware or adapter?
Results 1 to 16 of 16
There's two switches for PAL on the Canopus.... #6-on #5-off. Did you overlook that?
Originally Posted by thecoalman
#1 on = PAL
#5 power on input mode, on = digital
#6 input select mode, one = auto
I've tried them all in different positions but I think #1 is supposed to be "on" for PAL, and all the others are set to "off". -
How is the VCR connected to the ADVC?
Should be with just composite connection I presume.. -
Originally Posted by NewHomebrew
I have a 110 #6 switches between PAL/NTSC #5 switches between 0 ire/7.5 ire in NTSC mode or PAL/SECAM in PAL mode.
<decides to keep big mouth shut> -
Originally Posted by The_Doman
So then the only possibilties are the VCR is not putting out a TRUE PAL (maybe NTSC50?) signal or the ADVC can't handle the PAL signal.
Really strange problem there. -
Yeah, I am out of ideas too....
Did you try if everything works ok with other (NTSC) tapes?
Can you display the PAL output on your TV (if possible) to check?
Maybe there is still a PAL setting in the VCR wrong. (MESECAM?)
(oh, and the RF output you can't use with the ADVC, no need to check that option) -
The multisystem VCR outputs color capture with NTSC tape.
I don't have a PAL tv.
There's many options for output... NTSC auto/manual, PAL auto/manual, PAL>NTSC, SECAM, etc. I think I should be using PAL auto or PAL manual for a PAL tape. But they only give black and white capture.
Hi !
It's your IRE setting who is wrong. When you set the ADVC to PAL mode, you have to switch your IRE setting. In the way you have your settings now, the ADVC expects SECAM. It's all in the manual.
Let it stays in PAL-mode, and just correct your IRE setting to the opposite that you have now, and you should get colour. -
Originally Posted by Northpole
Changing your IRE setting should work - I know it have some connection to a certain setting when capturing PAL. I had this issue on my ADVC-300, and it's the same on the 100.
BUT - there is another possibility. I kind of remembering that I had to use S-VHS cable on the video and RCA on the audio as input to get color. Try that. (Supposing you have S-VHS output on the VCR. This in combination with the correct PAL >>IRE setting should do the trick.
Best of luck, and let us know. -
I wrote to Canopus tech support. This is what they said...
Are you working with PAL N footage? If so, PAL-N, PAL-M, and SECAM format is not supported with the ADVC-100.
If you are working with regular NTSC format or a supported PAL format, I need you to try and export from your PC to a TV using the ADVC-100 and see if the video display on your TV correctly. This will help determine if there is a settings related issue on the JVC HR-J82MS multisystem VCR .
Sincerely,
Canopus
The tape I am converting is from France, which they told me over the phone is SECAM format and not supported. I had no idea there were different flavors of PAL. Does this sound correct? What are my options for capturing a SECAM tape? -
France is SECAM(L)
Very much a "rebel" format, and hard to find players.Want my help? Ask here! (not via PM!)
When you play the tape and connect your VCR directly to the TV, can you see colors on the TV ? If so, you can solve this problem with chain in an converter who can convert different PALversions and SECAM to true PAL or true NTSC before the signal reatch your ADVC.
If your VCR outputs just black and white to the TV set as well, there is nothing you can do beside getting a VCR who handles these formats properly without trying to "pseudo-convert" them.
As Lorsmurf says - not easy to find outside France and some eastern european countries and a few South America countries.
Captured video is in black and white (NTSC vs PAL problem?)
By Helena in forum Capturing and VCRReplies: 27Last Post: 18th Apr 2023, 18:34 -
PAL Capture Black & White
By SGGS in forum Capturing and VCRReplies: 42Last Post: 9th Dec 2011, 04:12 -
PAL Hi8 Capture Black & White
By SGGS in forum MacReplies: 1Last Post: 8th Dec 2011, 09:15 -
Capture Card,Black and White
By I STANFORD I in forum Capturing and VCRReplies: 8Last Post: 28th Jun 2008, 10:26 -
video capture in black and white only
By oldboy29 in forum Capturing and VCRReplies: 8Last Post: 13th Jan 2008, 17:54
