  1. This might not be a typical question for this forum, but hopefully someone can help anyway.
    I am using the Mask Shape tool to create an elliptical mask around the frame of my video, so the corners of the picture are just blacked out.
    I'm using the Mask Feather tool to blur it so it looks natural, but... something is funky. When I adjust the feather bar to 100%, it looks perfect... the gradient is really smooth:
    Mask Feather: before rendering
    After I render the clip, however, the mask feather doesn't quite look the same. The gradient is nowhere near as smooth.
    Mask Feather: after rendering
    What's going on?
    Jan 2004
    I can see why... Huh??
    Doncha hate it when no one answers your question?
    I couldn't begin to know the answer to your FCP issue, but when I have FCP questions, I try the forums at www.2-pop.com. Hope this helps.
  3. You can also try:
    www.creativecow.net and go to the Apple Final Cut Pro forum.
    Your post will usually get a quick response.
    Good luck!
  4. Thanks, I've got to remember CC more often...
  5. Originally Posted by C_S
    I wonder if it is a "Safe/RT" issue see:
    http://www.rippletraining.com/engine/index.php?action=docs&doc=363
    Keeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
    Your source for iMovie answers and what not! ;-)
  6. That looks to me like the mask is rendering with a limited color palette (something like 256 values, verses your preview which is probably millions). Perhaps this is a limit in the masking feature of FCP?
