Hi
I am a newbie to the video editing thing and think it would be helpful to be able to print the glossary from the videohelp.com webpage. Is there anyway to download this file? I have searched but not found any info about this.
Tom
Hit "All" and then click on the first item. You then get a very long page which I believe you could print out.
If you hit "All" first all the definitions will be there. You have to scroll down past the list to see it.Yes, you get a long list but there are no definitions with it
Also you might want to "save as" text file and then print the text file instead of the web page. You could delete the list with no definitions that comes before the list with definitions.
Location Videohelp.com
By anon_private in forum Off topicReplies: 3Last Post: 24th Oct 2010, 22:59 -
Could the definition for h264 be added to the glossary?
By yoda313 in forum FeedbackReplies: 2Last Post: 27th Jun 2010, 08:50 -
How Can I Get VideoHelp To Look Right?
By DarrellS in forum FeedbackReplies: 16Last Post: 20th Jul 2009, 05:38 -
Videohelp for photography?
By anubis13 in forum Off topicReplies: 5Last Post: 27th Jun 2008, 16:49
