Hi,
What I'm hoping to do is rip my favourite TV boxset (13 episodes - 4 discs) to Avi's. Then I'm hoping to use DIKO to encode and burn all the Avi's to 1 or 2 DVD's (I've been told DIKO should encode all 13 Avi's to 1 DVD with excellent quality).
I'm using Fairuse to rip the boxset to Xvids @ resolution 640*352.
My first question is regarding resolution. Should I use 640*352 or should I use a higher resolution?
Any comments on the project? Should I use different software? Have I a hope in hell of getting all 13 episodes (approx 45min per episode) onto 1 DVD or should I aim for 2 DVD's?
Thanks in advance.
Hello,
Are you burning the AVI file itself???
You need to make sure the bitrate is low enough to fit on the disc space. Check the tools section for a bitrate caclulator.
Why not rip and transcode with dvdshrink???? If you're burning it to dvd you obviously have a dvd burner and you'll get MUCH HIGHER quality on a transcoding job than converting it to avi.
I'm ripping the boxsets to Avi's (Xvids) to remove all extras. I'll then convert to mpegs and author using DIKO.Originally Posted by yoda313
DIKO will work out the biterate for me. It'll encode the total to DVD size (4.2GB's approx).Originally Posted by yoda313
The idea is that instead of doing 1-1 copying of the DVD's if I rip to Xvid then encode and author using DIKO (Which uses a kind of Kdvd template afaik) I'll be able to get all episodes onto 1 DVD and not loose too much quality.Originally Posted by yoda313 -
Hello,
Nope - conversion will lose quality no matter what you do. Transcoding loses quality too but usually very minor and not noticeable too many people.Originally Posted by gidxg03
In dvd shrink you can choose title only and pick just the episodes themselves. There's a video preview window so you can see which are the episodes and which are the bonuses.
That would be a better bet than converting to divx than back to mpg. The less converting you do the better off the end result will be.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 20:23 -
Trying to rip my Firefly boxset to separate epis, but ..
By CBC in forum DVD RippingReplies: 14Last Post: 10th Nov 2009, 16:55 -
I want to make my own boxset.
By dafoe in forum Newbie / General discussionsReplies: 12Last Post: 22nd Sep 2009, 17:01 -
Error using diko
By thecrock in forum Video ConversionReplies: 4Last Post: 24th Apr 2008, 18:55 -
DIKO for dvd burning
By wristar in forum Authoring (DVD)Replies: 1Last Post: 29th Oct 2007, 15:41
