Probably a dumb question, but if I edit [crop] a DV file in VirtualDub and save the result (both audio and video) to a new .avi using Direct Stream Copy, will I lose any quality?
I'm thinking no but figured I'd ask to make sure.
If the answer is yes, is there a way to not lose any info/quality when saving the file?
Thanks in advance.
No. The video is saved in the original format.
Edit: Are you cropping parts of the frame out? If so then I don't think you can use direct stream copy. If you're doing a simple cut and splice edit then you can direct stream and not affect the video."Art is making something out of nothing and selling it." - Frank Zappa -
Thanks ZippyP.
All I'm doing currently is splitting a file into two parts.
I'll do some more editing later, but for now all I want to do is separate two different filming sessions. -
Even if you did do some editing other than simple copy / cut / paste- good software will render the project not re-encoding the unchanged portions, and as for the stuff that does require re-encoding, I don't think you'll ever notice a loss of quality anyway... that's the beauty of editing in DV with a good codec.
No direct stream copy in vegas pro 11?
By supercain in forum EditingReplies: 13Last Post: 18th Dec 2011, 03:10 -
The VOB equivalent of "Direct stream copy" in Virtualdub
By l-w-c in forum EditingReplies: 30Last Post: 21st Oct 2009, 15:13 -
direct stream copy of a mkv file Q
By Information in forum EditingReplies: 5Last Post: 20th Jul 2009, 15:06 -
Direct Stream Copy for All Formats
By bigMach™ in forum EditingReplies: 10Last Post: 11th Jun 2008, 14:02 -
Virtualdub direct stream copy takes _forever_. What's going on?
By Colmino in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2008, 09:01
