I have a SVCD with the file size being 1.56 GB. I really don't want to put this on 3 CD's. I tried cutting out the credits but it was still 1.46 GB. Is there a special way to burn this(overburn). I've never really used things like that. As you can probably do the math already, i'm using 80 min. Sony Cd's. If i can't fit it, any way i can reduce the size just a lil without losing much quality? Thanks alot
Re-encode to xvcd try sefys templates they are good quality?
That is all I can think of.
Unfortunatly in SuperVCD, most movies are 3 CD's, there are those who manage to somehow get it down to 2 CD's by lowering the Bitrate, but this is a very long process.
The only other way you can do this is by encoding to VCD instead, this will let you use a minimum of 2 CD's for almost any movie (2x74=148min movie/2x80=160min movie and so on) or you could try my SeVCD/SxVCD Templates, but again, they use the VCD format (352x240/28and you might not like the quality, or it might not even play on your DVD Player.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Can't convert very big file
By Julio33 in forum MacReplies: 3Last Post: 16th Dec 2010, 14:18 -
Too Big Clip File
By kamyogi in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2009, 06:51 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
ISO file to big for CD
By vagg in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 13:02
