Hi,
I tried to demulti some MPEG2 movie (a Capture) and I edited the movie in Goldwave to remove the hiss. And I resaved it to WAV.
The problem is the demultplexed audio was in MPA format (using MPEG-VCR) . I can't remultiplex the files togheter with a different format.
GSpot tells me that the MPA file is a MPEG 1 Layer2.
What I should do to save the wav into the format required to Multiplex it ?
thanks
Results 1 to 11 of 11
I am not sure what you are asking but, I just want it to be as the same format of the original file. It MPEG2 I think, captured video from my Hauppauge card.
I want to store the captures to DVD but not in a DVD format, just like files on HD. -
Hello,
you can convert to avi if your storing just the data files to save space. You can even use mp3 stereo in avi if you don't plan on converting it to dvd in the future (though of course it can be it just would save a step if you don't need to).
what Audio format can MPEG2 support beside MP2?
I tried some WAV but it doesn't seems to work with MPG2-VHS multiplexer -
Is there any other program than Besweep?
I appreciate the fact it free but it too complex and the GUI doesn't make any sence to me. -
Thank Soop, but after the convertion the new encoded audio have an horrible hissing in the backgroundOriginally Posted by Soopafresh
OK, I've played around with BeSweep and I figure how to change the encoder using MP2enc. But the output file produce hissing noise too
I try to change encoder from MP2Enc to 2Lame but I can't figure how to change bitrate of 2lame and the stereo mode.
How can I do so??
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
Does Anybody Need a Soundtrack or Score?
By TheIcarusDescent in forum AudioReplies: 59Last Post: 21st Jun 2011, 01:05 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
Soundtrack problem
By Den-2 in forum Video ConversionReplies: 2Last Post: 23rd Mar 2008, 09:42
