songs r difrf volumes on a hard drive does that mean its a bad rip or a bad hard drive?? are all drives the same right?? u cant buy a drive thats guna play low perorfamnce in files u play such as mp3, avi etc??
No. The hard drive will store data, or it won't. If a file is corrupt, it should not be able to access it.
It just sounds like you have made a compilation of MP3s from different sources, and the amplitude of the waveform (how loud it is) is different. Either that, or if you are talking about differences between albums then you can expect slight variance anyway.
You can normalise them using various utilities - have a search on Google for MP3 normalisers.
It won't be your hardware, anyway. I'm sure that's a relief to yourself and your wallet!
Cobra
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 15:28 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
recover *.mts files from external HDD ..tried restoring hdd software
By ravistudios in forum RestorationReplies: 0Last Post: 18th Mar 2010, 13:24 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
FIREwire HDD, NOT in my computer,update NEW acomdata HDD works great
By theewizard in forum ComputerReplies: 22Last Post: 20th Jul 2007, 02:01
