  1. I'm trying to convert this RMVB file to a DVD using WinAvi so that I can play it on my home DVD player, but the problem is that when I open up my RMVB file in WinAvi, it says that there are no usable audio stream.
    I've used AVIcodec to check my RMVB file and this is what it gave for the Audio info:
    Audio : 19.78 MB, 64 Kbps, 32000 Hz, 2 channels, 0x0 = RealAudio 8,raac-0, Supported
    I'm using WinAvi v5.8 by the way...
    Am I missing some audio codecs or something?
    Please Help!
    Dec 2004
    Australia
    raac is Sony ATRAC I think. You could try decoding the audio and feeding it seperatly into winavi, assuming that it accepts seperate sources that is.
  3. I don't think WinAvi accepts audio seperatly...
    Is there anything else I can do?
    Dec 2004
    Australia
    Convert the audio seperatly and demultiplex your video from the winavi output. Add the two for authoring.
