  1. Okay newbie here...my vcd seemed to burn fine(I have a compatible DVDplayer). The problem is this: I created a simple vcd with a menu and 2 short movies both in mpeg format perfectly compatible with nero. Now I burned it and the only thing my DVD player will do is play the menu page and will not let me choose between the seperate movie links. That is the only thing it will do is play the menu screen. I followed the step by step guide on VCDhelp.com. I would really appreciate any help on this or a point to where I can get help. Very frustrating!
  2. Normally to access each MPEG from the menu you have to hit that number on your remote (eg. #1). Esp with Nero Menu's which are beyond basic (XML script wise).
  3. Thank you,lol. That did it. Any way to make it revert back to the menu after it plays track 1 instead of leading back into track 2?
