I'm trying to convert ATSC/A-52 Dobly AC3 to MP2 using ffmpeggui. I click convert and get this in the status:
ffmpeg version 0.4.9-pre1, build 4723, Copyright (c) 2000-2004 Fabrice Bellard
built on Oct 20 2004 18:37:34, gcc: 3.2.3 (mingw special 20030504-1)
Input #0, ac3, from 'D:\DS\cl.ac3':
Duration: N/A, bitrate: N/A
Stream #0.0: Audio: 0x0000
Output #0, mp2, to 'D:\DS\cl.mp2':
Stream #0.0: Audio: mp2, 48000 Hz, stereo, 384 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Unsupported codec (id=11) for input stream #0.0
I've installed the codec from https://www.videohelp.com/tools?tool=AC3_ACM_Decompressor but this doesn't fix anything. I can't use BeSweet either because everytime I try to transcode it always transcodes to 128Kbps. Any ideas?
Many thanks.
It still does the same. Transcodes as...
[00:00:00:000] +-------- LAME -------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | MP3 bitrate : 128
[00:00:00:000] | Channels Mode : Joint Stereo
[00:00:00:000] | Error Protection: No
[00:00:00:000] +--------------------- -
Neither ffmpeg or BeSweet use installed codecs. I really wouldn't recommend ffmpeg for mp2 conversion though as the mp2 encoder is not the best quality.
You could try the last ffmpeg compile that I did though. Should accept AC3 as input just fine: http://www.aziendeassociate.it/cd//ffmpeg/ffmpeg.2005.01.11.7z
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
