I have some old movies I shot on VHS and wish to capture them in order to convert them to DVD-video format. Can anyone recommend a capture card in order for me to do this please, preferably something that can capture in AVI? Ive Pinnacle are good, I have one of their DV cards and its been great.
Thank you.
I'm particular to the ADVC-100. I bought it and have never looked back. Check the "capture cards" section listed at left and also run a search through the forums. There is a LOT of info on this subject on this site. Good luck.
3.141592653589793238462643383279502884197169399375 105820974944 -
Thanks a lot. I dont know of the ADVC-100. Im after something decently priced, and I'm based in the UK, by the way.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
Best S-VHS To best Capture card
By samturner01 in forum Authoring (DVD)Replies: 7Last Post: 15th Feb 2008, 18:00 -
Best capture card and method for VHS to DiVX?
By Vantage in forum Capturing and VCRReplies: 9Last Post: 4th Aug 2007, 14:11 -
suggestion for vhs capture card
By abbymat in forum Capturing and VCRReplies: 8Last Post: 28th Jul 2007, 00:57
