Avid requires a dongle to function? Whats a dongle?
It normally is a device that is connected to the card , that you can then connect a vcr or other device to it. Here's one for ATI
http://www.driverheaven.net/reviews/aiw9600pro/features.php -
In the case of Avid, as well as many 3D programs, the dongle is provided when the program is purchased. This is to prevent pirated programs from being used.
If you did not get a dongle with your copy of Avid, I suggest you contact the vendor and request a correction/replacement. -
It can also be a security device for software. Check here; http://www.sharpened.net/glossary/definition.php?dongle
It doesn't matter who you vote for. The government always gets in. -
This is a security/copy protection device usually attached to the parallel port. Newer ones are USB.
The story I heard was that they are named after one of the original inventors, a Mr. Don Gull, but I have no verification on this. -
http://en.wikipedia.org/wiki/Dongle
The word "dongle," as a word for something unnamed (akin to "doodad" or "whatchamacallit") has been used since the 1970s. Its origin is unknown. The American Heritage Dictionary, 4th edition, says it is "probably [an] arbitrary coinage." Claims that it was derived from the name "Don Gall" are an urban myth popularized by a 1992 advertisement for Rainbow Technologies, a dongle vendor.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
WiFi dongle compatible with Philips BDP3200
By xodeus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jan 2012, 23:14 -
3 dongle problem
By Mr anderson in forum ComputerReplies: 2Last Post: 6th Feb 2011, 09:43 -
Wifi to Ethernet dongle?
By rhegedus in forum ComputerReplies: 5Last Post: 24th May 2009, 01:53 -
carbon coder usb dongle error
By sid_dionne in forum Video ConversionReplies: 9Last Post: 9th Apr 2009, 14:27 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19
