how come when i zipped up a folder in winzip it came out smaller than the folder..but usually when i zip up folders they come up the same size??
Zip programs are compression utilites. The main reason to use one is to reduce the filesize. What happens is that some things get better compression than others. You can look at the files in the Zip archive through winzip and see their compression ratio. For example, text files or bitmap images are like raw data and can be compressed quite a bit. JPEG images are already compressed using and image compression scheme so when you zip them you'll see minimal if any size difference.
ConvertxtoDVD- Can I do other things while it is encoding?
By PhoneMatt in forum Video ConversionReplies: 1Last Post: 18th Dec 2011, 14:32 -
I think Im missing a few things
By craigarta in forum Video ConversionReplies: 4Last Post: 21st Aug 2011, 08:00 -
Things have changed
By Marco33 in forum Off topicReplies: 13Last Post: 23rd Dec 2010, 21:29 -
First Things First
By vusamoyo in forum ffmpegX general discussionReplies: 1Last Post: 31st Jan 2009, 04:53 -
trying to do 2 things at once
By AMGvh in forum Newbie / General discussionsReplies: 4Last Post: 17th May 2008, 19:55
