When i run my virus scanner i keep getting this file coming up but i cannot be deleted by the program and was wondering if this file is meant to be there, it is in the WINDOWS/system32 folder and is labelled mac80ex.idf
It's not a virus it's adware. Use a tool like AdAware or microsofts Anti-Spyware Beta to clean it in the safest possible way if you are scared to delete it manually. (not sure if it effects anything myself. I've never gotten this one) I think it has something to do with Bargain Buddy adware.
Speaking of MS spyware cleaner. I installed it, but don't see a way to start the thing. What up with that?Originally Posted by Poppa_Meth
are you sure you installed the Anti-spyware or did you install the Malicious software removal tool through windows update? The later one downloads every week or so and runs once on download. The actual Anti-spyware beta sets in your system tray all the time with active shields running and has an interface much like other spyware tools.
Here is the link to the one I'm talking about.
http://www.microsoft.com/athome/security/spyware/software/default.mspx
how to check width and height of a mov file
By moniia in forum Newbie / General discussionsReplies: 4Last Post: 31st Jan 2011, 14:19 -
mp4 file integrity check
By Bonie81 in forum Newbie / General discussionsReplies: 2Last Post: 16th Oct 2010, 17:30 -
How do I check if a file is HD
By no_alone in forum Newbie / General discussionsReplies: 5Last Post: 26th Jun 2010, 09:35 -
Check the Bitrate of mkv file
By maass in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 07:42 -
found very high quality free web site to check if a file has a virus
By jimdagys in forum ComputerReplies: 13Last Post: 26th Aug 2008, 09:48
