Hi! I have an Avermedia Tv capture 98 with the fusion878a chipset, Can someone of you point me to a web page where to download a driver that enables pal60 capturing, I know that this chipset can capture in pal 60 mode, but I don't know why manufacturer don't abilitates this possibility in the drivers release.
No OS problems, in my computer are installed Win 98, win2000 pro and winXP pro, so any driver is well accepted! ^_^
Thanx in advance. ^_^
Try here : this generic driver suports PAL 60 you might have to change the settings with graphedit as amcap is broken "unable to send graph to filter!!!"
http://btwincap.sourceforge.net/
I can use it to watch PAL 60 but I drop a load of frames when capturing Pal60 720 x 480 29.97fps or lower. Also the frames look like they have gaps in between. I read somewhere that this is related to my card needing 2 crystals?
_________________
<font size=-1>[ This Message was edited by: ironwood321 on 2001-12-30 10:08:12 ]</font>
photo capture from video signal hardware
By huegel in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 10:50 -
Do capture cards clean the signal ?
By davexnet in forum Capturing and VCRReplies: 18Last Post: 29th May 2010, 21:45 -
capture with twain driver
By zalves in forum Capturing and VCRReplies: 4Last Post: 27th Mar 2009, 15:46 -
Capture tv signal with mencoder
By mierdatuti in forum Capturing and VCRReplies: 1Last Post: 2nd Feb 2009, 02:39 -
Capture problems, PAL60 option
By CoronaStar in forum Capturing and VCRReplies: 1Last Post: 11th Oct 2008, 08:38
