I am considering buying a Sony Digital 8 TVR 480 to convert my collection of regular Video 8 tapes.
This camera plays regular and Hi 8 tapes.
Will this camera output the DV signal while playing the old Hi 8 tapes ?.
Thanks.
Yes. All of the Sony Digi-8 camcorders that can play Video 8 and Hi-8 tapes will convert to DV and output via the Firewire (i-Link) port.
Will all Sony Digital8 camcorders play analog 8 tapes? If not, where can I find a list of those that will?
If you still have your old Hi8 camera in (good) working order then you can ofourse use the passthrough funtion of a DV cam to digitize the tapes.
Then you are not limited to the D8-DV model line cameras -
I no longer have my old camcorder. Are the MiniDV recorders better quality?
The DV recording standard is the same for MiniDV and Digital8. The physical tape package is different 8mm vs MiniDV. Features are similar at the low end. Only MiniDV is available with higher end features.
For Digital8, 8mm and Hi8 playback is limited to 1x play for dubbing to DV. There is no picture in shuttle or slow motion capability with analog formats.
http://www.camcorderinfo.com/ -
I think all but the very bottom of the range ones will. The selling point with Digital-8 was the backward compatibility. Have a look at the camcorderinfo link that edDV gave for specific models.Originally Posted by chris1379
From 8mm tape to Final Cut...no camcorder
By cecile in forum Capturing and VCRReplies: 18Last Post: 23rd Aug 2011, 23:53 -
Mini DVD tape: HD vs Regular vs HDV
By CliveJ in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2011, 20:34 -
I have about 60 Hi8 and regular 8mm camcorder tapes that I can't get toplay
By Chris McDowell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Jun 2010, 19:12 -
playing Digital8 tapes in 8mm tape backup drive
By jrh69ca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Dec 2009, 13:46 -
8mm tape source filmed twice
By Dieu in forum EditingReplies: 9Last Post: 17th Nov 2009, 20:14
