Hello, i listen to alot of online radio stations,
and i would like to run line from my pc to the radio.
Any thoughts on the right cables i should use, my radio
takes rca cables.
Thanks![]()
Hello,
You need a y splitter that takes the mini headphone jack to rca plugs. They're very inexpensive and can be found in any electronic store or big shopping store like walmart. They should both have the stick out prong to plug in to the output of the soundcard and the rca output of the y splitter also needs to be stick out type.
Kevin
EDIT - Heres a pic:
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You may also want to pick up a filter to elliminate the hum that is normally generated from the DC and AC. Radioshack has them, its called a ground loop something or other.
Internet radio player?
By AlanHK in forum Software PlayingReplies: 2Last Post: 22nd Jan 2011, 06:31 -
Car radio fault
By didikai in forum Off topicReplies: 2Last Post: 26th Oct 2008, 16:17 -
Do you listen to Sports Talk radio?
By yoda313 in forum PollsReplies: 18Last Post: 27th Feb 2008, 09:11 -
Do you listen to streaming internet radio?
By yoda313 in forum PollsReplies: 13Last Post: 25th Jun 2007, 20:54 -
RIAA Seeks Royalties From Radio
By BJ_M in forum Off topicReplies: 8Last Post: 25th May 2007, 01:06
