    Oct 2002
    INdiana
    anyone running shoutcast on their computer? im trying but cant get it to connect.
  2. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Are you behind a firewall or router? That could be a problem....i've done shoutcast but it's been a good while. It's kewl though!
    Later
    Rog
    There are many ways to measure success. You just have to find your own yardstick.
    Oct 2002
    INdiana
    im behind a router but i have the setting that allows that computer to have port 8000 open.
  4. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    hmm not really sure. i know it has problems with routers will have to give it a whirl. If you have a modem you could try seeing if it works that way w/out the router hooked up. If it does, then the router is blocking it. If it STILL doesn't work then it's some other problem
    Later
    Rog
