Greetings.
Whenever I use the following script:
With a video captured with a Canopus ADVC-100 using WinDV, and encoding with TMPGEnc Plus. The resulting video when played on a DVD player, the areas of action display weird or with bars or something even though the video is encoded with a field order at B or A. It is like the script or TMPGEnc doesn't respect the field order specified.Code:# Created by AVSEdit LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\Convolution3d.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\ReInterpolate411.dll") avisource("D:\filename.avi") Converttoyuy2(interlaced=true) ReInterpolate411() crop(4,4,-4,-12) SeparateFields() odd=SelectOdd.Convolution3D (0, 32, 128, 16, 64, 10, 0) evn=SelectEven.Convolution3D (0, 32, 128, 16, 64, 10, 0) Interleave(evn,odd) Weave() DoubleWeave.SelectOdd() AddBorders(8,8,8,8) LanczosResize(352,480) ConvertToRGB(interlaced=true)
Any suggestions or what I might need to change so that it displays properly?
The problem happens with either VHS, Hi8 or Mini DV.
Thank you.
Take Care.
JuanMa -
Are you sure the video you capture is bottom field first. This script is made for bff video. You might try to eliminate the doubleweave.selectodd and see what happens.
From what I have read here on the board DV video is bottom field. So the video should be bottom field.
I will try to eliminate that line and check it out.
Thanks.--
Take Care.
JuanMa
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 17:57 -
To Script or Not To Script, that is the Question... (Custom Videos)
By TheMcD in forum EditingReplies: 2Last Post: 21st Oct 2010, 11:11 -
Online video converter script
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 15th Apr 2009, 06:26 -
Video Conversion Script
By paug in forum Video Streaming DownloadingReplies: 1Last Post: 16th Oct 2008, 03:49 -
Video Editing problem with Final Cut and Flip Video! Help!
By caputr in forum MacReplies: 2Last Post: 22nd Jun 2008, 12:52
