I just made a copy of my DVD and there was slight pixelation during a scene.
Does anyone know what that is the result of? Is it due to sharpness or smooth? How can I fix it, if it can be fixed?
If its just "slight" pixelation its probably just compression that cant be avoided.What movie was it?
If its some 4 hour epic that you crammed on to a 4.7GB disc than consider it a masterpiece.COPIED OVER 600 DVDS SO FAR -
If you didn't make use of some of DVD Shrink's features, you could redo the disc (the original, that is). Use Deep Analysis, then use AEC, if the disc is compressed alot try using the smooth or maximum smoothness setting (I almost always just use smooth or sharp, depending how much it is compressed).
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
Pixelation during playback
By Port in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Aug 2011, 16:01 -
Pixelation in certain frames while playing files in a DVD player
By aarelovich in forum Video ConversionReplies: 8Last Post: 4th Feb 2010, 15:47 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
disappearing pixelation
By AlecWest in forum Off topicReplies: 5Last Post: 29th May 2007, 10:24
