I was following the great advice here when having problems with a copy proteced audio stream in quicktime movie files to caputure the audio seperatly with Total Recorder. Now, total recorder works fine with me with all other programs, but for some odd reason it doesn't capture the audio of mov files played with quicktimeany idea what the problem could be? (if that matters - using quicktime.5.02, Windows XP on a Pentium 4 computer.)
I use Total Recorder all the time and it records eveything, including .mov files... did you try converting the .mov to .avi with RadVideoTools?
Yes, tried that and it converts without audio which was why I was trying to record the sound seperatly with Total Recorder but it doesn't seem to recognize audio, doesn't record at all. Got no problems with other files, just mov files.
Cannot open .mov files in Total Media Extreme
By edong in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Jan 2012, 23:18 -
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 01:40 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 20:23 -
convert .VOB file to .MOV - sound out of synch
By bdaul in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2008, 11:36
