i used smartripper->flaskmpeg(0.6)->served to tmpgenc(2.01).
i then used vcdeasy (1.03)(with vcdimager 0.7.11) to create
the vcd for checking purposes (no menus, no chapters)
the resulting vcd had about 5 flaws at various points. 'flaws' mean very brief 'flickers' (not sure how to describe
them)
when viewing the mpg file on the computer with windows media
player, there were no problems at the exact points
any idea what the problem could be...
i noticed that vcdeasy/vcdimager had messages that autopadding (of X number) took place because of some unalligned sections
if so, how do i produce perfect alligned mpg file...
thanks...
i've resolved the problem...
before burning the vcd, i used tmpgenc->merge&cut to split the mpg file. as the type, i used the default type
mpge1 - system(automatic). when i changed the type to mpge1 - video cd, everything is fine...
Add a Video file to a burned DVD
By FDiez in forum Newbie / General discussionsReplies: 4Last Post: 17th Jun 2011, 05:59 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
