Has anyone tried this "speed Optimizer" it's from this website http://www.speedguide.net/downloads.php
Here's the description:
Description: The TCP Optimizer is a free Windows program designed to help optimize your Internet connection. Just download and run, no installaion required. The program makes it easy to find the best MaxMTU value, test latency and tweak all the important broadband related registry parameters. The Optimizer can be helpful with tuning any Internet connection type, from dialup to Gigabit+If you need help with the program, read our broadband tweaking articles, the Optimizer FAQ, and/or visit our Forums. As an alternative, you can try one of our generic Registry patches instead.
I was just wondering if...
1. It works
and
2. is it free from spyware and other crap
Results 1 to 9 of 9
It works, if you understand what you're tweaking with it.
Beware that you may be voiding the agreement you made with your ISP if you use this.
It's got no spyware or other crap.
Speedguide.net are reputable people.Cheers, Jim
My DVDLab Guides -
kool thanks but what do you mean by "you may be voiding the agreement you made with your ISP if you use this" that?
It means that if your ISP catches you, they can cut your service.Originally Posted by 808smokey
The tweaks it performs on your system may void the agreement. If your ISP only allows 2 simpltaneous connections via any given protocall, and this tweaks it to 4, you could be in trouble.
If your ISP has maxed out the MTU at 1500, but you find your system works better at a different number (not likely), etc. etc.
Read the fine print before you go adjusting a bunch of settings you don't understand.Cheers, Jim
My DVDLab Guides -
I tried it but it didnt work i looked at their faq on what to do and i think i followed it right, at least i bloody hope so!!
im with broadband 0.5 megabit so that wld be DSL right??
i restarted and noticed no difference..does this mean ill have to make adjustments to the registry?? -
Do you get your internet thru a phone line, or TV coax cable? Phone is DSL, other is cable.
Cheers, Jim
My DVDLab Guides -
Go to http://www.dslreports.com/tweaks and run the "Tweak Test".
Read all the nfo and you'll learn a LOT about RWIN and finding your DSL-MTU (it's not the same as setting Cable-MTU).
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Internet "Dropouts"
By Sakuya in forum ComputerReplies: 9Last Post: 20th Aug 2009, 10:52 -
"Internet Revenge". A Strange Tale of Cyber Jealousy!
By moviebuff2 in forum Off topicReplies: 1Last Post: 27th Oct 2007, 05:20 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
