Hi,
I just bought this capture card. I've been able to capture PAL VHS, but when I try to playback/capture ntsc VHS, I get a bad/distorted picture.
I tried configuring it for ntsc, but when I go into capture profile setting, it doesn't allow me to change anything.
I've emailed Leadtek also.
Any feedback is appreciated.
Rav
When I play the NTSC VHS, I still get full colour, but when I set the video standard on winfast to ntsc, the picture goes black and white but is complete.
I may be mistaken, but I think there are two versions of this card. One for pal the other for ntsc capture. I have one, but it has been awhile since I looked under the hood.
I'm in Australia which PAL is standard. Maybe that explains it, but the program allows you to set PAL/NTSC.
My VHS Player supports both Pal/NTSC.
(The top 3/4 of the video plays ok, but the bottom 1/4 has a line than repeats the very top of the picture) -
I think that your VCR is using PAL60 when playing NTSC tapes.
vcd4ever.
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 12:38 -
Winfast 2000 XP input jack is a PS/2?
By jabberdau in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2009, 14:46 -
WinFast A340 Xbox Capture help
By lj106 in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2008, 12:10 -
Looking For A Windows 2000 Compatible Video Capture Device
By acid_burn in forum Capturing and VCRReplies: 16Last Post: 29th Nov 2007, 11:42 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 11:00
