I have seen several references to making sure that your CD and/or HD are set to DMA, I am using an ultra-DMA HD with Win98se and can't find anywhere these properties can be set.
Thanks in advance for giving me a clue!
Claudia
Claudia,
First, check in your system BIOS what are the settings for Primary/Secondary IDE interface. Make sure they are set to match the transfer protocol of your devices (HD, CD/DVD-ROM). Choose the maximum supported transfer method.
In Win98SE, go to Start|Settings|Control Panel|System;
Under "Device Manager" tab, click in the [+] next to CD-ROM to show the CD/DVD units in your system. Choose one and click "Properties".
In the second tab you'll see a set of 6 check boxes. To activate DMA, check the last (from top to bottom) rightmost box. Click OK. In the pop-up message, click OK again.
Do the same with your hard disk(s) and reboot your machine.
To see if the changes were effective, proceed as before and verify if the option boxes are still checked for each device you changed.
Good luck!
(Where are you from?) -
Thanks for the tip. I had looked in Device Manager before and completely missed that DMA box, must have been momentary blindness! Has helped my captures a lot!
At the moment I live in the Deep South, otherwise known as Mississippi. Thank goodness for the Internet since it is almost impossible to find people who share my interests here...
Thanks again!
Claudia
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 13:15 -
DMA PIO Reg Prob Key Deleted returns after reboot
By tonib95 in forum ComputerReplies: 14Last Post: 4th Feb 2008, 10:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 22:35
