Results 1 to 15 of 15
  1. Banned
    Dec 2004
    SE4
    does ne1 know if going from 98 straight to xp would need an upgrade cd if i didnt wanna loose all my work?? or does upgrading from 98 to xp not require an upgrade cd??
  2. Member Heywould3's Avatar
    Apr 2002
    always on the move
    yes you need the CD how else would you load XP.. if you get the upgrade version of XP then you will need to have an existing windows OS disk to qualify for the upgrade price.. 98 2k me etx will all work... you should back up all your work before installing any OS BTW
  3. I think even when you go to Install XP over 98, it will format, will not upgrade,Like going from 98 to 98se.
  4. Banned
    Sep 2004
    Inner Circle of Thought
    It gives you the option whether to upgrade to do a new install.
  5. Originally Posted by bazooka
    From 98? I didnt think you could do an upgrade,It just formats and installs XP, But going from 98 to 98se would be an upgrade withought formating and deleting files.
  6. Banned
    Dec 2004
    SE4
    aight cheers 4 the help ppl..thats answered that then..
  7. Banned
    Sep 2004
    You can upgrade from 98, but you cannot upgrade from 95.
    If you have windows 95, you must buy the full install version.
    The line of thinking is also if you are running 95, your computer is not adequate enough to run XP.
  8. Banned
    Dec 2004
    SE4
    cheers 4 the info mate
  9. Banned
    Sep 2004
    No problem
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    please post non video related computer stuff in the computer forum. moving you.
  11. Member Prot's Avatar
    Dec 2003
    Oregon
    A clean, fresh install is always the preferred way to put XP on your system. It will still ask you to insert your 98 disk for verification.
    Back up all your data files you need first. Another point is not all applications and drivers for your 98 OS will be be compatible with XP, so that needs to be kept in mind, too.
    TANSTAAFL
  12. I bought the XP upgrade disk (pre-SP2) and it said I had to run the CD from Windows 98. Couldn't run off a floppy boot into DOS.
    Perhaps later upgrades are different. That would be better.
  13. Banned
    Sep 2004
    Originally Posted by gmatov
    Bazooka,
    If your 95 machine is so inadequate that you need a Full version, how the hell would it install? It's still inadequate.
    I was just quoting Microsoft. They were telling people that were running 95 that they needed the full version. Then they later said that if they were running 95, they needed a new computer.
    XP should not be that much different than 2k to upgrade to.
    XP has greater hardware demands
    I don't think converting to NTFS will make your Word docs or other such things unreadable.
    It doesn't
  14. Member Skith's Avatar
    Bottom of the ocean
    Bazooka,
    It doesn't
    This is a liscensing issue. Win95 does not qualify for an "Upgrade" pricing to XP. XP Upgrade discs ask for proof of a previous *Qualifiying" microsoft operating system (Win98/2k). The "upgrade" cd's will not allow installation if you can not provide proof (a CD, or previous installation on the computer).
    I would advise a full backup (of all important documents) at the least. This is even more so if all your documents are on the C:\ drive with win98.
    The best defense against (potential) disaster is to be prepaired.
    Edit:
    /off topic
    Bazooka, I like your new title. It seems, some how, usefull!
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  15. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    At the time XP was released, Windows 95 had dropped off the support list, so it was no longer a valid, supported OS.
    By far the best results will come froma fresh install. No legacy drivers, no registry crap, just nice and clean. This is not always practical, and thankfully the upgrade is pretty thorough and foolproof. Legacy hardware, such as scanners and parallel port drives, may give you grief.
    One of my clients is a school where we upgrade fairly regularly and rarely have major problems.
    Sage advive to back everything up though, as there are no gaurantees.
    Read my blog here.
