Is it possible to play video, which was encoded to Nero Digital, on a computer which has no Nero products installed.
In other words: is it possible to instal Nero Digital codec alone, like any other codec needed for software video players.
Thank you.
Results 1 to 11 of 11
you can use the 3IVX codec for playback ... you also can install just the nero codec ..... but since you have to buy nero to get it -- and use it ... might as well just install the whole thing ...
i tried it -- installing just the nero codec manually .. i got video but no audio (so far) ..
For Windows XP, try installing both the Xvid and official Divx codecs. Also, different Media Players may make a difference. Windows Media PLayer isn't the best. Try VLC.
Nero Digital mp4 files will play on both Mac OS X and Linux. There is no requirement that a computer user own the Nero Digital product for playback. But some Nero Digital options such as subtitles and chapter selection will not be available.
Nero Digital offers a few encoding choices, however. I do not know about cross-platform compatability for the new AVC codec. And when I use the standard Nero Digital settings, I always choose the Simple Profile (QuickTime Compatability) option -- this is available under the Expert Mode -> Advanced options.
I have the free Xvid and Divx 5 codecs installed on my Mac OS X system. Both are free and easy to download. Maybe other mp4 codecs will work as well.
Linux is a bit trickier, it depends on what is included in the particular distro, and what you have added to it, such as Xvid and any other codecs you can find. Some Linux distros will play Nero MP4s without addition. I find Mplayer is the best for Nero MP4s on Linux.
Cheers
adcvideo -
the nero mpeg4 is easy to play back on most anything -- i was referring to the AVC codec only
Please tell me where is that codec (Nero Digital) and how/where you installed it manually ?Originally Posted by BJ_M
You said that you got no audio. I don't understand why audio should be a problem (unless it is in Nero mp pro format).
Why tools like Avicodec or GSpot do not recognize video encoded in Nero Digital ? This is not so new codec.
I've been Nero user for a long time, but I only recently have decided to start playing with that Nero Digital and I've been pleased by results.
My brother do not use Nero and could not play that video, so that's why I am interested if it is possible to play that video format without having Nero installed. -
regsvr32 NeNDVid.ax
etc .... just register all the *.ax files ... -- ... NeNDVid.ax is the main codec .. use Filmerit to get a handle on which codecs and files are in use .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Sony Digital Video Codec
By AnchorMan in forum Software PlayingReplies: 19Last Post: 20th Mar 2024, 06:17 -
Western Digital HD TV Media Centre - Missing audio codec support
By Hcw87 in forum Media Center PC / MediaCentersReplies: 5Last Post: 21st Jul 2009, 14:55 -
MKV, vibos codec issues with western digital HDTV
By stevencg in forum AudioReplies: 8Last Post: 6th Apr 2009, 21:11 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
