Can a tracking problem affect only the audio and not video? I have a tape where the video looks fine and the audio is fine, but you can hear electronic noise that ruins the sound track.
My VCR is a JVC 9911 that is supposed to do automatic tracking. The remote doesn't even have tracking buttons.
The noise you are hearing is from the audio hifi heads on the video drum,they are not tracking properly,not much you can do,try cleaning the heads or use another machine.
This usually means the recording deck was screwed up.
Not the player.Want my help? Ask here! (not via PM!)
Originally Posted by sync
If still no avail try to switch to MONO sound as the last option. -
Originally Posted by The_Doman
Does VHS support a stereo and a mono audio track? -
I had a tape like this once. I bypass the problem with manual tracking... But it wasn't easy!
When I had acceptable audio, the video was distorted. When the video looked perfect, the audio was terrible.
So, I captured twice the same tape: One for Video and one for audio. I split the capturing to quarters, to avoid huge lipsynch issues and later manually, I try to adjust audio / video stream. I manage to fix it, but it took me much time...
Of course this is not a solution. Just an alternative to do your job done!La Linea by Osvaldo Cavandoli
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 12:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 09:32 -
Help! VHS tape suddenlt decided to stop playing. Some sort of configuration problem..
By stevie P in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2010, 13:24 -
VHS tape recorded with a problem camcorder screwing up players
By perceptionist in forum MediaReplies: 11Last Post: 4th Nov 2007, 20:34
