    Jan 2005
    Sweden (PAL)
    Hi
    I want to backup one of my movies but it seems to be hard to find a good dvd-ripper who have all the funcions I want:
    - It rips the dvd directly into Divx 5
    - It can encode the sound (ac3) directly into mp3
    - It supports subtitles
    - It is easy to use (not so important)
    If anybode know a ripper with all this funcions please tell me.
    Thanks in Advance!
  2. Ive never seen a ripper that can do everything you want it to do . Best of luck trying. Its not gonna happen
    Life is like a pothole, you just have to learn to get around it.
  3. I'm afraid that it is impossible to do what you are asking. However, it is very easy to do in a few simple steps. First, download DVD Decrypter and AutoGK (click the names in my post here, it will take you to the tool). Next, check our guides section (on the left of your screen) and find an AutoGK guide (try sorting by tool). Follow it.
    I doubt you'll need the guide - AutoGK is incredibly simple to use. If you don't like it, try Dr. DivX.
    All you need to do is:
    - Rip your files to your hard drive using DVD Decrypter
    - Point AutoGK at it and make a few simple settings
    - Leave it for a few hours
    Good luck!
    Cobra
