Hi
Im using Premiere Pro 1.5.
I have a project with 100 small clips. I want to scale the clips down to 80%. Is there any way I can select them all and just do the scaling once or do I have to do it separately on each clip?
Hakster
Results 1 to 1 of 1
denoise clips before importing in premiere
By codemaster in forum EditingReplies: 0Last Post: 27th Apr 2012, 16:13 -
transitions hard to add on multiple clips in premiere
By codemaster in forum EditingReplies: 11Last Post: 7th Jan 2011, 11:34 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Adobe Premiere. Difference between frame size and scaling?
By vid83 in forum EditingReplies: 4Last Post: 13th Dec 2008, 21:57 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
