Heya,
I backed up my Eternal Sunshine of The Spotless Mind onto my Prodisc DVD-R. I used Dvd Decrypter and Nero 6 for the whole process, everything seems to be working fine (in terms of recoding, burning, etc).
Now here's the problem. I put in the DVD into my Panasonic DVD F-84 player. So far so good, it got to the title menu no problem. I then press the "PLAY" section of the menu and *BAM* the whole dvd stopped!! BUT when i press PLAY button on my remote, the movie would go on smoothly again. Does anyone have this problem at all or is it just me?
Sincerely,
dydy
That is very weird. Would you do us a favour please? Could you try it again, writing to a DVD-RW (so you don't waste a disc) and see if the error is duplicated? That would rule out a glitch in the burning.
If it doesn't work, would you like to try using DVD Shrink to recode the video? If you select your DVD burner as the output device, it will use Nero to burn your disc automatically - it would be just as easy as your current method. Again, burn to a DVD-RW just in case!
I'm afraid I don't know enough about this to offer a solid answer, but I can try to solve the problem with you like this (provided nobody else has a definitive answer, as I suspect they might).
Good luck to you!
Cobra -
Well I found out what the problem is. It's actually my DVD player that is screwing up... so sad.. I only had that DVD player for half years or somethin.
did u try it on another dvd player or on the computer? the computer is more forgiving than a dvd player. i had probs with that movie too i ended up just do a re author and just snagging the movie alone. just to let u know if u have anymore probs
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
Problem with Blu-ray backup playback
By Tommy-T in forum Authoring (Blu-ray)Replies: 25Last Post: 26th Sep 2011, 18:52 -
1408: Backup Problem
By taboo in forum DVD RippingReplies: 5Last Post: 28th May 2009, 21:15 -
xvid avi problem when playing on eternal dvd player
By myname77 in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 10:26 -
Dvd backup problem
By RemainsHuman01 in forum Newbie / General discussionsReplies: 5Last Post: 20th Aug 2008, 02:01 -
DVD backup problem
By 557953 in forum Authoring (DVD)Replies: 5Last Post: 21st Aug 2007, 11:30
