I have a TEAC Dv-W50D, and have been burning quite a number of DVDs with it. DVD-R, DVD+R, DVD-RW and DVD+RW have all worked fine.
But suddenly, I'm unable to write to my DVD+RW disks, I get the message in Nero that the disk is not writable. Writing to DVD+R and (over)writing DVD-RW still works as always.
Does anyone have any suggestions as to what has happened?
At first I thought that I had written to the DVD+RW too many times and that it was no longer rewritable, but this happened to all my DVD+RW disks at once, some of wchich have only been written to once before.
Edit: By the way, the DVD+RW (and DVD-RW) disks I'm using are Verbatim.
Results 1 to 10 of 10
No, it says that "This disc is not rewritable and therefore cannot be erased. Please insert a rewritable disc."
I can erase DVD-RWs as always, though. -
Have you tried turning the computer off and then back on?
I don't have a bad attitude...
Life has a bad attitude! -
Dirty lens or laser going out are two possible reasons. I had the same problem with my Sony DRU-500a. At first I thought my DVD-RW(s) were going bad, but this happen all at once. After I cleaned the lens I was able again to erase and write to my DVD-RWs.
Since then I replaced this writer with a Plextor 712a. Knock on wood, I've had no problem writing to the same DVD-RW(s). -
This happens to all the DVD+RWs I have (about 20 of the same brand). I havent tried any unused DVD+RWs or other brands yet, as I hoped to be able to figure this one out without buying anything.
But perhaps I should try cleaning the laser lens... do you have to use a particular DVD lens cleaning kit, or is a CD-player cleaning kit good enough? -
wait
u sure u arnt looking at the RW label thinking there rw's?
because the RW logo is used on both +r and+rw's
look on the bottom of the disc, if its blue/pupleish its not a RW
its its like a silverish color then its a RW
edit, RW as the black and white logo
i just fully read ur problem, u only got one dvd burner? got a friend with one to test the disks out?
u know u gotta actully reformat them right? -
Yes, I know they are RW's because I've rewritten most of them at least once already.
I know they have to be reformatted(or erased) but the writing software wont let me do that anymore. Seems the drive recognizes the +RWs a +Rs...
Even tried updating the writers firmware, which didnt change anything.
The one thing I can think of that has happened lately is that service pack 2 (XP) was installed by the IT-dept. Could that influence things? -
Now I've gotten hold of some other DVD+RW media and it seems like they work fine. So it is the Verbatim DVD+RWs that no longer work as DVD+RWs, and not the DVD burner.
I'm puzzled.
DVD+RWs no longer play
By Iconoclast in forum MediaReplies: 31Last Post: 26th Mar 2012, 21:59 -
Trying to use DVD+RWs with Imgburn and Megastor 16xDVD9
By w6rlf in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2012, 00:02 -
Archived unfinalized DVD-RWs--can i play them?
By mpmp0 in forum Newbie / General discussionsReplies: 23Last Post: 30th Aug 2008, 23:31 -
DVD+RWs going bad
By lmemsm in forum MediaReplies: 18Last Post: 12th Jun 2007, 14:40 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 13:51
