I'm thinking of getting an IPOD, and I have a question about how its used. I have my entire cd colletion on my computer, but I don't use iTunes. I just have the files in a folder and use winamp to play them. My question is, is the IPOD like other mp3 players (iriver forexample), you just use the included software to take songs from computer, or do they need to be downloaded from iTunes?
What We Do In Life, Echoes In Eternity....
the itunes software will search your computer for mp3 files and put them on the ipod for you.
one thing that kinda sucks about itunes/ipod is that it requires id3 tags.. well it doesnt exactly require them, but it wont sort them very well on the ipod unless they've got id3 tags. -
is itunes the only way to get them onto the IPOD?
What We Do In Life, Echoes In Eternity.... -
i think there are some other 3rd party applications that will allow you to put them on the ipod.. you'll have to look around the net.. check out ipodlounge.com
ok thanx....
another Ipod Question
By angryassdrummer in forum Portable VideoReplies: 5Last Post: 11th Mar 2011, 03:35 -
Ipod Itouch Question
By ultraman36 in forum Portable VideoReplies: 7Last Post: 19th Jul 2008, 08:08 -
ipod touch resolution question
By Abeille_qc in forum Portable VideoReplies: 2Last Post: 23rd Mar 2008, 10:57 -
Another MeGUI Newbie Question--How Do I Get It To Look Right on my Ipod?
By CubDukat in forum DVD RippingReplies: 1Last Post: 3rd Mar 2008, 11:53 -
Ipod syncing question
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2007, 08:12
