Thanks edDV, I checked out the AVID page again, and you're right, the workstations are optional. I will follow your advice and check out the specialized forums. You say they have a learning curve of a couple years. How long of a curve do you think Premiere and Vegas have?
Results 31 to 44 of 44
Brian
Originally Posted by edDV
very well put --
i use both avid systems and vegas -- vegas is by far the easier system to use (learn) and is MUCH faster to do anything on except when it comes time to render -- But people that have been editing for many years will most likely have learned on avid mcx or express and up and will find all the avid versions very straightforward (after using it for 5 ++ years) , all avid platforms share a common interface and look and feel ...Originally Posted by viveresempre
though it is slow to render (vegas) -- though you can set up a render farm ..
you will find it much harder to import a lot of different formats in AVID ,AVID is (depending on version) a Quicktime based product , or for the cheaper versions - DV .. it is not user friendly for different formats or even mixing different sources ...
Vegas is resolution and format independent - AVID is not
AVID is the way to go though for film match back and EDL (OMF) support with Protools and finishing on composer .. a big strength with the avid pro system ...
vegas - has more limited EDL support and you can finish on Xpri .....
they actually can be both used - if you have the budget ... and need film matchback support ..
I am one of the moderators on the DMN vegas forums - but I am impartial also ...
here is good article on a TV station that uses full avid systems switching a lot of stuff to vegas for broadcast ..
http://www.sundancemediagroup.com/articles/wfaa-Vegas.asp"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Wow, very helpful. I think I'll be getting back to you with some questions.
Brian -
I have been thinking, and am beginning to think I might not want to make the investment that Avid represents. Even though I can get it for cheaper than V egas and Premiere, I will have to upgrade to 1 GB of mem. and upgrade my video card. Also, spending 5 + years to master the program that I want to use now seems a bit over my head. Not a final decision, but just a thought. However, back to my original question: if I were to pick between Vegas and Premiere, which would I choose?
Brian -
well forget the premiere element version -- not worth it ... they stripped out to much ...
between premiere pro and vegas - they both have their points ...
this question has been asked many many times on the creativecow forums (vegas and premiere) , the dmn forums (likewise) and on the sony vegas forum
- maybe on the premiere forum also - though i dont follow that one anymore ...
so you might want to do a search on those forums ..
http://www.dmnforums.com/cgi-bin/displaywwugindex.fcgi?dire=4&endday=14&forum=sonic-foundry_vegas
http://mediasoftware.sonypictures.com/forums/default.asp?ms=1
http://www.creativecow.net/forum/view_posts.php?forumid=24"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hi,
Instead of saying one software as superior than other, why not mention the differences or specify the details of superiority? If time is the factor in these softwares, many may not mind it. If anything else like interface, build quality, quality of reproduction etc., etc., that will be worth mentioning.
Take it seriously to reply as many are fools like me in this field.
Bye -
I said or intended to say all four (premiere, vegas, avid Xpress, final cut pro) have a multi year learning curve to become proficient and to understand some of the 2nd and 3rd order issues. That is why choosing the support community is as important as choosing the software. I've tried to differentiate these 4 programs and communities so you can decide which matches your goals.Originally Posted by viveresempre
These are all professionaly targeted products. As you go up in software sophisticaltion, all the handholding wizzards disappear in exchange for greater control and creativity. Like with Photoshop, you need to gain knowledge and skills to make these programs work for you. -
I just did some lucky web surfing. Or unlucky. Sony discontinued the Vegas academic line for individuals. If I were to buy Vegas + DVD now, it would cost $800, as opposed to the academic pricing, $419, on Adobe's video collection (Premiere Pro, After Effects, Audition, DVD). In this light, I think it would be ridiculous to go Vegas. Just a thought. What do you think? I'm still considering Avid...
Brian -
Are you sure about Vegas adademic?
See here:
http://www.academicsuperstore.com/item/?tname=245037&title=Vegas%AE -
they discontinued it -- but now brought it back i heard ..
Thanks to all who contributed. I am still in the process but am much better advised now.
Thanks.Brian
Anything Adobe Premiere 5.1 does that Vegas Pro 8 doesn't?
By brassplyer in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2012, 02:04 -
Laptop screens and Vegas 10 / Premiere Pro 5
By Outtasight in forum EditingReplies: 4Last Post: 16th Oct 2010, 18:43 -
Use After Effects and Vegas together, or use Premiere instead of Vegas?
By Morten in forum EditingReplies: 47Last Post: 13th Aug 2009, 14:05 -
Canon HG10, Vegas or Premiere Pro CS4?
By Woodserr in forum Video ConversionReplies: 9Last Post: 30th Jul 2009, 23:36 -
Can't get video to import into Ulead, premiere or vegas
By nagihcim1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Aug 2007, 22:37
