hi
i've got and xvid file, and with it are three types of sub files, idx, sfv and sub, how can i add any of them to my xvid permanently so i can make VCD later, i've tried using vobsob and ffdshow for my sub extension file but its not working
please help
What I normally do is to encode the movie in Tmpgenc Plus and Vobsub would automatically insert the subs during the encoding process.
If you enable vobsubs in ffdshow and the file is being decoded by ffdshow then you will get subs if your encoder is inputting via ffdshow. If named the same then directvobsub (auto-loading version) should automatically kick in.
For avi-->VCD you can always frameserve to TMPGEnc via AVISynth and use vobsub to add the subs. Should be faster encoding that way. -
HI
ALL YOU GUYS HAVE DONE GIVEN A LIST OF POOGRAMS TO USE WITHOUT GIVING A GUIDE HOW TO USE THEM, I AM JUST A BEGINNER
PLEASE HELP
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
