I am ripping all of my dvd movies to my HD using DVD Decrypter. Is there a way to create a single file to click on to play a movie off my HD that would act similar to inserting the DVD to get the whole movie to play? As it is, when I watch the movies, I have to click on the .vob's each time and sometimes there are several and it gets to be a pain to have to open a new one each time one ends. Thanks!
When you rip with DVDDecrypter, use No File Splitting option in the settings section. This will rip all the parts of the movie, but create a single VOB file that you can play continuously.
Alternately, if you play back the ripped movie with PowerDVD, the newer versions allow you to select "Open DVD File on Hard Disk Drive". Just select the VIDEO_TS.IFO and the entire disk should play just as if you had inserted the DVD in your DVD drive complete with menus and everything. -
https://www.videohelp.com/forum/viewtopic.php?p=1159360#1159360Originally Posted by NoekIf in doubt, Google it.
Vegas Movie Studio Platinum 9 startup...
By Anonymous4374945 in forum EditingReplies: 5Last Post: 8th Jul 2011, 14:28 -
Question how to change icon of software icon
By jimdagys in forum ComputerReplies: 3Last Post: 10th Oct 2009, 05:47 -
How to cut VOB-file and create DVD from VOBs?
By john999UPR in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 11:07 -
Create DVD from several VOBs ?
By flash70 in forum DVD RippingReplies: 3Last Post: 8th Jun 2008, 10:51 -
How create menu to Vobs ??
By Seasonal in forum Newbie / General discussionsReplies: 8Last Post: 23rd Sep 2007, 15:10
