  1. Hi!
    Well, I have downloaded a dvd-5 from the net (.rar files) and unpacked them to a VIDEO_TS catalog. When trying to burn with nero recode I've get the error "A VOBU adress is out of bounds, this may by caused an invalid DVD navigation structure."
    The .vob files seems ok, I can view the film in ex. showtime.
    Is there a tool to rebuild a correct structure so that nero or any other burning prog will accept?
    Kindly
    /Pelle
    Apr 2004
    Miskatonic U
    Assuming that this is a legitimate DVD download, and not a copy of a commercial film, you could try IFOEdit or PGCedit, if you know what you are looking for. I don't know of anything that might easily scan and identify the offending part though.
    Read my blog here.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Maybe load VIDEO_TS.IFO into IFOEdit and press the "Get VTS Sectors" button, then save the updated IFO file ?
    It sounds like a few DVDs I've seen, where there are VOBs that have been removed from where they should be, only leaving the main feature. If this is the case, and you want movie only anyway, it might be worth your while to try this:
    http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit (after moving every file bar the main movie VOBs out of the directory and renaming these main movie VOBs to VTS_01_1.VOB, VTS_01_2.VOB ... and so on if required).
    If in doubt, Google it.
