I just installed the new version 2 that I downloaded from the registered member area. Everytime I go to run it I get this error:
Version:SVCD2DVD 2.0 RC3
Type: System.IO.FileLoadException
Source: SVCD2DVD
Message: The located assembly's manifest definition with name 'AxInterop.CodeLock' does not match the assembly reference.
InnerException:
StackTrace: at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb 7d5()
at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor()
at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
and here is an image of the error window:
What am I doing wrong? I also rebooted the system after the installation. Also I installed it over the version that I had installed B4.[/img]
§î®Th®ăsh€®
Can you try uninstalling. Deleting everything in the SVCD2DVD BETA folder and reinstalling?
Thank you very much ChrissyBoy worked like a charm
Is there a loc for a tutorial for this new version or a video?
§î®Th®ăsh€® -
Zwei-Stein installation error.
By sjs in forum EditingReplies: 2Last Post: 1st Feb 2011, 15:30 -
Installation error
By johnsonk in forum ffmpegX general discussionReplies: 2Last Post: 14th Aug 2009, 12:05 -
Installation Error In Leopard
By Lefty! in forum ffmpegX general discussionReplies: 3Last Post: 6th Dec 2008, 05:14 -
vegas 6.0 installation error
By scd250 in forum Software PlayingReplies: 3Last Post: 27th Feb 2008, 22:09 -
Installation error -
By ruggerjvd in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2007, 10:06
