I have a twinhan dvb-s card that I use to watch satellite with. I have the video going out to the tv and the audio is sent out to the tv thru a little adapter that splits the sound out to my pc speakers and to the tv. Well my problem is when I want to send sound out to my tv I get a buzzing sound when I try to turn it up loud. This also happens if I take the adapter out and just plug the sound going out to the tv. I have a 1/8 plug to rca adapter that connects the composite audio to the Audio in on my tv. I'm using gold plated RCA brand composite cables. Does anyone know why I'm getting this buzzing sound and how can I get rid of it? thanks
Sounds like a ground loop problem, you need a ground loop isolator. here is a link on what it looks like, http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=270-054 hope this helps.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078
TV makes a buzzing sound when scenes are bright.
By Denvers Dawgs in forum Newbie / General discussionsReplies: 10Last Post: 30th Nov 2011, 11:32 -
How to Remove Audio Buzzing?
By Tchail in forum RestorationReplies: 5Last Post: 1st Sep 2010, 04:13 -
downloaded video file, has buzzing audio when put into encoder
By efiste2 in forum Video ConversionReplies: 3Last Post: 22nd Jun 2009, 12:55 -
Filtering Buzzing Noise from Audio
By Tchail in forum RestorationReplies: 4Last Post: 12th Sep 2007, 23:49 -
Western Digital WD2500JB 250GB making buzzing sound
By ChapGrip in forum ComputerReplies: 1Last Post: 26th Jun 2007, 17:17
