Today I purchased the Pinnacle Express DV card and SW. I'm using this with a sony digital camcorder and when I play my camcorder directly to the TV, the quality is perfect. The process I am using to capture and burn the video is this:
1. Capture video from camcorder (in .avi mode). Not sure if this is changeable.
2. Do small amounts of editing
3. Created a VCD and SVCD disk to play in DVD. Don't own a DVD writer yet.
The problem is that when I play either of the 2 formats of CD I've created, the picture quality is not that great. You can definitely see a grainy appearance (very pixely).
Is this caused by saving the data in .avi format? Do I lose quality at this point, or am I losing quality with the creation of the CD in either VCD or SVCD format?
How do I make the quality on the CD as good as the quality when playing directly from my camcorder?
Or, is this a limitation with not owning a DVD-R?
My computer is not the latest and greatest, but should be sufficient.
Thanks,
Mark Gillman
gillman@denalisoft.com
You can send the edited movie back to a brand new Dv tape.
In this way You can get the best quality.
For me, captured in Dv format with uleadvideo 5 and save
the edited movie in Dv format too.
Then use Tmpgenc to encode it to svcd,using the svcd template.
The svcd made seems good to me.
Try a small clip and see the result.
DVD Player problem playing .avi
By dexter30 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Sep 2009, 01:18 -
xvid avi problem when playing on eternal dvd player
By myname77 in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 11:26 -
problem playing Philoco dvd player moga juniour 400
By akhtar123a in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 10:17 -
will playing compressed dvd's on an upconverting player increase quality?
By fonzbear2000 in forum Newbie / General discussionsReplies: 14Last Post: 16th Nov 2007, 22:15 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 18:41
