After Installation of svcd2dvd 2.0 rc 3 i get the following error:
Part of the error is in german,so roughly translated to english: "absolute path informations are necessary"Code:Version:SVCD2DVD 2.0 RC3 Type: System.ArgumentException Source: mscorlib Message: Absolute Pfadinformationen sind erforderlich. InnerException: StackTrace: at System.Security.Util.StringExpressionSet.AddExpressions(String[] str, Boolean checkForDuplicates, Boolean needFullPath) at System.Security.Permissions.FileIOPermission.AddPathList(FileIOPermissionAccess access, String[] pathListOrig, Boolean checkForDuplicates, Boolean needFullPath, Boolean copyPathList) at System.Security.Permissions.FileIOPermission..ctor(FileIOPermissionAccess access, String path) at System.Environment.GetFolderPath(SpecialFolder folder) at x3284ccece41ee22b.x067e7d569898d5a4..ctor() at x3284ccece41ee22b.xfa6d102debc45529..ctor() at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.SetVisibleCore(Boolean value) at System.Windows.Forms.Control.set_Visible(Boolean value) at System.Windows.Forms.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322395(String[] xce8d8c7e3c2c2426)
i read the other postings but i have a clean fresh install and dont have rc1 settings left in my registry. The values are all not set.
Any ideas?
Greetings
Toni
Have a look at:
https://www.videohelp.com/forum/viewtopic.php?t=255680&start=0&postdays=0&postorder=asc...dinformationen
See if that is the same issue that you have.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 15:12 -
avidemux doesnt see whole file.
By hate_machine420 in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2009, 12:07 -
DVD Doesnt even register
By ORI0N in forum Authoring (DVD)Replies: 1Last Post: 16th Nov 2007, 14:56 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 10:05 -
Newbie that doesnt know much and doesnt know where to put her query.
By emilymeg in forum Newbie / General discussionsReplies: 22Last Post: 10th Jun 2007, 13:46
