Are there any other registry entries that can be made to tweak the AVI encoding, I've already tried the one for deciding when to switch to half-D1(which seems to work best with a cut off point of 3500kbits), are there entries for min/max bitrates when using 2-pass encoding(so I can guarantee the bitrate doesnt drop below a certain level during vbr, ie 1000-9000kbps), using more than two passes, or using custom resolutions(svcd or 352x240) etc.?
At the moment no there isn't but i may well add an "advanced" config screen for people like yourself.
My issue with all of this is that i have tried to make the avi to dvd process easy and accessable to the average person. I feel that if you want a high level of control over the process then there are a mass of great tools out there which allow such tweaking. That said i want my tool to be good so i will be adding more to it over time but like i say it may well be in "expert mode"....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
cheers chrissy, look forward to a more "advanced" version in the future. Main requests would be more than 2-pass encoding and 352x240 resolution (i have tons of old Avi TV episodes in this resolution!)
capture VHS with Virtualdub , color tweaks
By smartel in forum Capturing and VCRReplies: 10Last Post: 19th May 2011, 08:34 -
Canon Vixia HG21 need setting tweaks...
By Heyjoojoo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Jan 2010, 14:35 -
x264encopts..looking for tweaks..
By triptec in forum DVD RippingReplies: 3Last Post: 19th Dec 2008, 17:46 -
Encoding AVI
By Broka in forum Video ConversionReplies: 32Last Post: 5th Dec 2007, 03:00 -
Canopus ADVC 300: best settings / tweaks ?
By fabweb in forum Capturing and VCRReplies: 3Last Post: 12th Sep 2007, 07:34
